Anyone waiting for DFI will be happy to know that their NForce4 boards are ready
LANPARTY UT nF4 SLI-D
LANPARTY UT nF4 Ultra-D
LANPARTY nF4 SLI-DR
LANPARTY nF4 SLI-DR
Bullitt said:They've really packed a lot of stuff on that board, I hope the chipset cooler right behind the PCIe16 slots wont interfere too much.
Frallan said:RAID 5 if Ive understood correctly... Read at http://www.dfi-street.com/forum/showthread.php?s=&threadid=3447&perpage=15&pagenumber=22 to find out more...
nForce 4 chipset variations
The three different versions of the nForce 4 chipset share all the above features, but there are still some considerable differences. Lets look into them, starting with the low-end nForce 4 socket 754 chipset.
The nForce 4 chipset (Socket 754)
This variant seems set to be the budget nForce 4 release, given that it will be Socket 754 only, with support for Athlon 64 and Sempron chips. Aside from the socket, the two main differences between the basic nForce 4 and its higher-end siblings are in the Hypertransport link between the processor and the chipset and in the Serial ATA controllers.
The basic nForce 4 uses an 800 MHz Hypertransport link, as opposed to the 1000MHz connections found on the nForce 4 Ultra and SLI. This might translate to slightly reduced performance in demanding graphical applications, since less bandwidth will be available. The Hypertransport bus will be locked in the nForce 4, preventing users from raising its speed to increase system performance. The basic nForce 4 also uses standard Serial ATA 150 controllers instead of the brand-new Serial ATA 2 controllers found on the higher-end nForce 4 chipsets.
The nVidia firewall will be present, but not the updated ActiveArmour version with hardware support that is seen in the nForce 4 Ultra and SLI. The processing load will be applied to the CPU not the chipset, imposing a performance overhead.
The nForce 4 Ultra
The nForce 4 Ultra chipset will probably become the favourite among the three existing variants, and its certainly the one that manufacturers have jumped on first. It has a full 1000MHz Hypertransport link incorporated, as well as the new Serial ATA 2 technology, allowing a full 300MB/s of peak data transfer with compatible hard drives.
The Ultra features nVidias new ActiveArmour hardware firewall technology. This offloads firewall operations onto the network controller built into the chipset, freeing the CPU from the processing load imposed by firewall operations. If it works as advertised, this should be a great benefit to gamers, allowing them to protect their systems while still squeezing out maximum performance. In addition, the firewall now supports the Intelligent Application Manager feature, which monitors and controls applications in a similar manner to popular software firewalls like Zonealarm.
The nForce 4 SLI
The nForce 4 SLI (Scaleable Link Interface) is slated to be the high-end gamers chipset of the family. Its features are identical to those of the nForce 4 Ultra with one huge exception; it has two PCI Express x16 slots, sharing 16 Hypertransport lanes between them.
The chipset is designed to use a pair of SLI compatible nVidia video cards, and employs a switch built into the chipset to split the 16 PCI Express lanes that would normally feed a single PCI Express video slot into two sets of eight.
When equipped with two nVidia SLI compatible cards, this chipset will enable the cards to work in tandem, splitting the rendering of frames between themselves. What effect this will have on performance is not clear, but early benchmarks on the web have shown up to an 85% frame rate increase in some situations. Currently the nVidia 6600GT, 6800GT and 6800 Ultra are the only video cards compatible with nVidias SLI mode.
While this setup does mean that each video card only has half the normal bandwidth of an x16 PCI Express slot available to it, the benefits of SLI operation should significantly outweigh this fact. This is especially true considering that modern video cards do not come close to taking full advantage of the bandwidth that a full PCI Express slot can offer.
The nForce 4 SLI chipset can also be used normally with a single PCI-Express card in one of the slots, as the switch allows all 16 PCI-Express lanes to be applied to a single slot. The single card does not have to be SLI compatible.
DoMeHardR said:I thought all the new nf4 were going to pci-e
MaMMa said:are you serious, boy that stinks if it you are rightI just barely got my bfg 6800 gt oc AGP and nv5 silencer I havent even put on yet
synergy321 said:any guess'es if the ultra will accept the xp120 i mean based on the layout? I really reallly want this the ultra *bumps newegg* lets go....
I saw a guy taking preorders and said the mobos will come in the first week of February -- but that's here in SE Asialessthanjakejohn said:How long will they take to reach vendors?
Nope. What we see are a whole lot of jumpers to set between single and SLI mode. Not as elegant as MSI or ASUS's solution but I suppose they're trying to save as much space as possible to put in a lot more featuresArvig said:As an aside, notice the SLI controller card slots in between the video card slots? Looks like that maybe their controller card will sit upright maybe? On the ASUS the card sits sideways.
Teg said:Nope. What we see are a whole lot of jumpers to set between single and SLI mode. Not as elegant as MSI or ASUS's solution but I suppose they're trying to save as much space as possible to put in a lot more features![]()
Chaotic Master said:Almost hit the submit order over on googlegear...zipzoomfly.com.$199 for the Asus SLI. Damn I hate having choices. If that Tyan Dual proc and sli board comes out at under $500 while im waiting on the DFI im going to have to back to the drawing board. Luckly i can get dual DVI pci video cards from work for "FREE", cant afford PCI-E card just yet but need to get this media server up before 200GB's become obselete.
Dioretsa said:Wait... does this mean we won't see an AGP 939 board from DFI?
NOOOOooooooooo!!!!!!!!!
orkan said:anyone upgrading to top end cards in AGP should be shot in the face.
Decelerate said:They will have an AGP 939 board.
NF3
Dioretsa said:Really? Rad!
Is it coming out soon, like with the nForce 4 boards? I don't want to upgrade my 9800 Pro.
