DFI Nforce 4 Ultra Problem
kid_at_sd
I just built my new system (A64 3500, geforce 6600, Corsair XMS xpert ddr 400, DFI nf 4 ultra). When i tried to install windows i keeped geting IRQ less than equal erros, so I thought it was the memeory. I ran memorydoc and both 512 pairs passed with flying collors. I was able to install windows with just one piece of ram, but I cant get the system to run with both peices installed (Iv tried every type of combination on the slots). Could it be the motherboard?
You say you've tried running with one piece of RAM. Have you tried both sticks singly? Also, are these a matched pair? Was this a failed dual channel install?
Lastly, I don't know memorydoc but I wouldn't necessarily assume that the memory is clean...
Iv tried both pieces single and they both work fine alone. Iv also tired 2 other pieces of ddr form a system that I know Works (Those were corsair xms ddr 400 too). As a pair I had the same problem. All the ram Im using is match pair. when the memory is in both slots i cant get windows to run, but using a single stick everything works fine. Aditionaly, I am using the ram in dim slots 2+4. I cant get the dual channel to work :(
From everything I have read try the following. In BIOS disable dual channel then try both sticks installed. Also make sure you are running at least the 0201 Beta BIOS (There are three other newer beta bios' that that). Also increase the chipset voltage to 1.7 and the LTD voltage to 1.4
kid, make sure your vdimm is above 2.65v ... so, do the following:
- seat a single stick in slot 2.
- boot into bios and change vdimm to 2.7
- shutdown, and seat the two sticks in slots 2 and 4.
- boot up.
let us know if this fixes your problem.
Other things to consider:
- make sure you have a native 24-pin atx connector on your psu.
- there is a resistor on the board right next to the 12v 4-pin jack; make sure you haven't bent it while plugging in the connector.
cheers.
