DFI NF4 Ultra SATA2 compatibility?
Specialist[X]
will the ultra-d board support sata2 w/ncq technology? and will the thermalright xp-120 have a difficult time, or a slightly small hassle slapping on?
I can't answer the NCQ question as my current drives don't support it. I can tell you that the xp-120 fits just fine but brings up some issues populating ram slots. It all depends on which direction you mount the xp-120 (there are two ways). You'll also want to have some lower profile ram sticks as the clearance can be close. Try this page, it helped me out. http://www.xtremesystems.org/forums/showthread.php?t=50963&page=1&pp=25
I am running 2 seagate NCQ dirves in a raid 0 configuration with no problems.
I haven't seen nay reports of people having dropped drives, but thats just what I have not seen...
I also don't recall a report of the Maxtor NCQ drives working, but like I said haven't seen a report of them not working.
Guess I wasn't very helpful.
but do any of you know if it supports sata2/300? please respond asap as the one day deal on newegg is about to end.
my pqi turbo pc3200 2-2-2-5 sticks will work in dual channel in this then right?
