DFI NF4 Ultra-D boot issue
microTech
Alright,
I have this issue that I have never encounter/seen before. The problem has been narrowed down to booting up. The computer boots up fine ONCE, and only ONCE. If it is shutdown then booted again or restarted I goes into a reboot cycle. before the windows login screen is able to appear the system keeps rebooting time and time again.
However, if it gets shutdown, and both the cmos is reset and JP1 boot pin is 'reset'. It will then boot up fine and the computer works just fine. But then same thing will happens all over again unless the pins are reset manually.
I have rolled back the bios to an older version to see if it would affect anything... but it did not. I just don't have any idea what to attempt next as this situation makes no sense to me.
Appreciate any comments or suggestions.
-Mike
Try setting your ram overvoltage control jumpers back to defualt. worked for me:D
