DFI NF4 SLI and Overclocking
Mnx4
For those who have overclocked this board, did you tinker with the extra timings, like those not found in 3-4-4-8 and the 1T or 2T? Those are the only ones that i've really messed with besides voltages, multiplier, HTT. I'm just having problems oving my 4200+ and I can't seem to be stable on prime for over 6 hrs. Specs are in the sig. I'm doing
3-4-4-8 2T timing @ 2.9V and have been testing HTTs of up to 270MHz. I tried doing 268 last night and ran prime but the comp froze after 3 hrs or so. Procs at 1.6 V and at load, I get max 50 C or so. I've been able to boot into windows with a 280 FSB, but prime had an error after the first iteration. Any Ideas?
Memtest stable? Don't even bother to attempt to boot into Windows without being memtest-stable. Also, that board is very finicky with ballistix memory, so it might take some time to get the timings tweaked right. The DFI forums have a decent guide on the additional memory options in the bios; you might want to check that out :)
Yeah i have here and there. I just haven't done extensive testing with the settings b/c i didn't want to screw anything up...
6 hrs prime (even 3) sounds pretty stable to me. i can do 2 instances of 32m super pi, and thats all i need. i have never had a bsod or hang except when i screw around with turning my fan speeds down. check out xtremesystems.org, just about everybody uses the dfi, check the xtreme bandwidth forum and the amd forum for exact settings for your ram. dont get caught up in the "if its not prime stable for a year or 2 it sux" mindset tho.
very truly yours,
politenessman
6hrs prime or (3hrs) is not stable. Speaking from experience, while my system hardly had any issues when I was only 4-8hrs prime stable for a while, I did have some corrupt file copying a couple of times and several other issues.
Once I tweaked with the settings enough to get over 24hrs prime stable, never has there been a problem.
I am sure you can game on 3-6hrs prime stable, but please do not call your system stable.
Yeah, that's kinda what I figured. I mean, it's stable for gaming, but i'd really like to submit my overclock to the chart in these boards and I can't do that unless I have 6 hrs stable.
QFT!
QFUT.... :rolleyes:
Prime95 is buggy. I've found it to be especially buggy with AMD cpu's also. But it is necessary.
i can call my system stable because i do not have any issues with software i run. my machine runs fine. i dont use it for work, but i doubt anybody here is subcontracting for nasa, either.
my system doesnt hang or crash. my vid en/decodes fine. my games run as long as i want to play them. my machine has been up now about 4 days running dc++. i can run 2 instances 32m superpi. i have a backup disk that i copy files to all the time, with no errors. this may not fit some arbitrary definition of stability needed to get on a list somewhere, but i can call it stable.
but thats just me.
very truly yours,
politenessman
