Dfi nf4 s939 wont post/boot
I have not had the same problem as you, but I have had problems with this board that prevented it from POSTing properly. A few things to try/check:
  • Verify that there are four power cables plugged into the motherboard (main ATX, 4 Pin P4 cable, 4 Pin Molex, Floppy power connector)
  • Reseat the graphics card/try the graphics card in the other slot.
  • Check that your memory is getting enough voltage.
The board is supposed to be picky about power supplies and memory that will work in it. I have never had a problem with it in that regard, but if you can, you may want to try a different brand memory/PSU just to see if that helps. It would probably also help if you list all the components in your computer.
