DFI NF4 dual channel - help!
laserbeam
Hi All,
I have the DFI NF4 Sli-D mobo. And very nice it is too, except for one thing. The manual says that dual channel can be achieved by pairing memory modules in slot1/3 or 2/4. I have an XP-120 cooler with the heat pipes overhanging slot 4 so 1 & 3 are the go-to slots for me.
However, when I boot the system it reports:
"Please install One RAM Module in DIMM 2 For Single Channel Operation and 2 Modules in DIMM 2+4 For Dual Channel Operation"
The memory I'm using is Corsair 4400C25PT and it's working fine. I'm hoping that someone around here can help me sort this out without me having to turn round the XP-120.
Assuming that I do have to reinstall the heatsink will I need to reapply arctic silver? The system is 24 hours old. Is it fairly easy to detach/attach a heatsink without destroying the thermal interface? Any pointers you can give me will be greatly appreciated.
Also, I wonder whether my ram modules will be too tall to fit under the back of the XP-120 if I turn it around....
Thanx in advance,
D
xtremesystems has info on the xp120 and ram slots and postiton. but i still think it should work in 1/3 ... try xs though
