DFI NF4 24 pin connector?
Bubbers214
Can anyone confirm or deny that the DFI nforce4 board requires a 24 pin power supply? I know that the connector on the board is 24 pins but i have heard of many using a 20 pin on alot of other boards. I have seen speculation that a 24 pin is required for this particular board but can anyone confirm or deny this? Thanks.
Yes, the DFI needs a 24 pin connector. People say that the A8N-SLI works with just a 20 pin connector, but it didn't for me, even on my Antec 550W PSU.
My MSI SLI system is using an Antec NeoPower 480W PSU and it runs perfecty (this PSU is 2.0 compliant).
Ralliart Evo
20pin works for me on my a8n, but can't overclock much on my current psu.
Currently completely stable at 206fsb with 12v crying at 11.3v.
My current psu only has 15amps on the 12v.
Is there a list of PS's that have the 24-pin connector? I've been browsing thru the PS's at newegg and whether or not it has a 24-pin connector isn't usually listed.
Hmm, I may try this only connecting 20-pin on the A8N. There is no way to damage it, if it doesnt work? Ive got a good PSU, PC Power&Cooling 510 ATX Deluxe, hopefully it will work.
I assume there are two pins left on each side, with the 20 in the middle being used?
I havent looked.. I just assumed the clip to hold the connector on, was in the middle, putting two pins on each side. How does it go then, Im too lazy to open my case and look.
