DFI Motherboard Question
kirk
I heard from a friend that DFI motherboards have a problem with things such as the bios chip failing for no reason.
Has anyone else had or heard of this kind of problem?
nope. some ram compatibility issues, and some vdimm voltage fluctuations on the older revs, but i never heard of a bios chip failing "for no reason"
That is strange, because that is exactily what happened to me, I shut down my computer and started it back up and it said that my bios was now ACPI compatible.
no more than any other brand.they have their set of issues and bios chips sometimes go down bu there not known for this.they have ram issues and power supply issues and there bios is complicated but i would not purchase one because you think the bios is gonna fail.if your not too experienced with computers and setting them up,and if you dont have the correct hardware that is reccomended for them to run successfully then think hard about buying one.they can be a headache to get running correctly.great boards if you know what you are doing.please read dfi street forums and do your homework before making a decision to buy one ,get hardware that works well with them and you should be good to go.they are not by any means plug and play unless you get very lucky.getting them to boot can be a hill to climb and to boot into windows can also be a challenge.if you want plug and play then you need to be looking at asus,abit,gigabyte,biostar,msi,epox.many good boards out there.if you quest is the absolute highest o/clock then dfi is it.if your looking for a moderate o/clock with minimum problems then one of the other brands may be what is better for you.if dfi is your choise then be ready for the challenge,you may enjoy it if your patient,and the byproduct is you mite learn something new.good luck.
I have been building my own systems for 10 years or so, and have been overclocking for almost the same amount of time. I just found it strange that it would just die like that, working one second and then after restarting dead the next
yes i have had one LP_ultra D that has been RMA'ed three times with bios chip failures.
and had another that has been rma'ed for replacement three times due to bad power regulators.
however DFI to their credit (no credit to DFI street) has been good about the rma's and has admitted to me there was a probelm with some MB's .
i haven't had nearly as many problems with asus or even the el-cheapo ECS's
DFI is the king of overclocking--if you can get one that works--lol
