DFI Mobo's that hard to set up?
XLeezardx
[H]ardChef
Hey guys, I just recently ordered a DFI Lanparty SLI-D Mobo and after doing some more research, I heard its very hard to set up to work. I heard u have to enter in 26+ timings for the RAM, run memtest for like 8 hours before i even start loading up the O/S and reboot everytime i install drivers. WTF? I am coming from ASUS and I have never had to do that. I mean, I heard even after you get it running, you will prolly run into more problems which will cause more headaches. I mean i can understand if i was to overclock, but just to get it running stock???
I never had to do that. I have the same board. I just installed the thing, installed the OS then overclocked the CPU. I didnt really overclock the memory much, I did run memtest for 2-3 hours. That was basically it.
This was my first DFi Board, I switched from ABIT and I didnt regret it. I would go for it. I am planning to upgrade to Core Duo, and I'm planning on getting the DFI Nvidia 590 Sli Intel the moment it comes out.
I'm not a DFI cheerleader, buts its a good product, I think you'll like it.
