DFI MOBO Problems
cvfd1615
Hello,
I have a DFI Lanparty NF4 MOBO w/ AMD Opteron 148 Processor... Today I try to turn the computer on and it doesn't do anything - nada like its dead... So I check my power cord.. Turn the Power supply off and back on and all that good stuff... The LED 1 Light comes on and stays so that indicates its getting power but it will not power up at all.
I have tried the switch on the MOBO POWER and it doesn't do anything and the switch on the chassis of the case.
Any suggestions?
I have had this EXACT same problem on my DFI LanParty board. Look at the residual power indicator on your board. After you press the power button, it probably just sits there and blinks.
What I had to do was unplug the power cord from the PSU and literally wait 15 minutes. Then, plug it back in and turn on the PC.
I ended up just purchasing a new ASUS board with the heatpipe design. Haven't had a problem yet.
I've tried to do what Mr. Said and LED 1 stays on but the computer will not come on at all...
Any other suggestions?
kind of elementary, but do you have all 4 power connectors plugged into the motherboard?
To test the PSU.
Unplug it from EVERYTHING but 1 fan/light... and the wall. Make sure the back switch is on.
Using a paperclip, short the GREEN and any black wire on your PSU ATX cable (the really big one). It should turn on... Google has some good results. IF the fan runs/light turns on, it's not the PSU's problem.
Start up with some speakers, or the mobo speaker, attached... Does it beep?
Remove all the cards/ram/processor etc... Reseat everything and try again. If it still wont boot, clear the CMOS battery (there should be a jumper, or just take out the silver battery on your board, wait 30 seconds, and replace it).
If none of this works, you'll have to RMA your motherboard.
Well the power supply turned the fan on but it wasn't turning very strong. I dug out the original PS that I got with the case and it turned it on with no problem at all.
Guess the Antec Smartpower has gone bad
Will RMA it and send it back for exchange.
Go grab a PSU tester from your local Radioshack/Circuit City/Best Buy. They are pretty cheap, and you'll probably use it later.
Using a PSU tester is way better than simply shorting the green wire and ground wire and seeing if the PSU comes on.
I totally agree. Are you sure you shorted the PSU right? Linky
Now, the PSU that "came with the case" powered up the system or just the fan?
The PSU that came with the case when I bought it is working fine w/ no problems.. The levels are fine in voltage wise and all that and am not having any problems with it this far. I done exactly what you advised Paper Clip/ Green wire to a black wire and it spun the fan 120MM but it wasn't very fast compared to this stock power supply.
