DFI LP UT P35 T2R question
minijjm66
i just installed my new DFI LP UT P35 T2R motherboard along with 4 gigs of gskill memory. in vista x64 it only shows 3.25gigs. anybody have any solutions to this? i tried reinstalling the memory and vista and that didnt work. here's my system specs-
CPU-Z 1.41 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name Intel Core 2 Duo E4300
Code Name Conroe
Specification Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
Package Socket 775 LGA
Family/Model/Stepping 6.F.2
Extended Family/Model 6.F
Core Stepping L2
Technology 65 nm
Core Speed 3061.3 MHz
Multiplier x Bus speed 9.0 x 340.1 MHz
Rated Bus speed 1360.6 MHz
Stock frequency 1800 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache (per processor) 2048 KBytes, 8-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory Frequency 340.1 MHz (1:1)
CAS# Latency (tCL) 4.0 clocks
RAS# to CAS# (tRCD) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 14 clocks
Command Rate (CR) 2T
System
System Manufacturer OEM
System Name OEM
System S/N OEM
Mainboard Vendor DFI Inc.
Mainboard Model LP UT P35
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Date 08/10/2007
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, G.Skill
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, G.Skill
Module 3 DDR2, PC2-6400 (400 MHz), 1024 MBytes, G.Skill
Module 4 DDR2, PC2-6400 (400 MHz), 1024 MBytes, G.Skill
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
DirectX Version 10.0
Looks like "4096" and 4 X "1024" to me.
Where did you get the 3.25 from????
