Sep 8, 2008 #1 S siralexu Limp Gawd Joined Mar 25, 2008 Messages 281 Regarding the DFI LP DK P35-T2 I saw that it uses a 8pin cpu power connector my questions is will it work with just a 4pin connector ?
Sep 8, 2008 #2 L lowteckh Supreme [H]ardness Joined Jul 23, 2008 Messages 5,073 Think TDP matters more than whether it's quad or dual core.
Sep 8, 2008 #3 S siralexu Limp Gawd Joined Mar 25, 2008 Messages 281 il be using a intel e2160 till i upgrade to an e5200 or a e7200 im guesing the 4 pin is going to be enough to overclock the dual core procesors
Sep 8, 2008 #5 S Seb1 Gawd Joined Feb 2, 2008 Messages 524 Yes, it will work - but if you will use it with a quad core CPU, then you should better use an 8 pin CPU power connector.
