DFI LanParty woes (Need Xpert help)
Stormlifter
TOPIC resolved, my RAM is the bad... it died.. :'(​
I keep getting
World of WarCraft (build 4769)
Exe: C:\Games\World of Warcraft\WoW.exe
Time: Nov 8, 2005 11:34:28.421 PM
User: Stormlifter
Computer: HK418
This application has encountered a critical error:
ERROR #132 (0x85100084) Fatal Exception
Program: C:\Games\World of Warcraft\WoW.exe
Exception: 0xC0000005 (ACCESS_VIOLATION) at 001B:00759F03
The instruction at "0x00759F03" referenced memory at "0x0000003C".
The memory could not be "read".
WoWBuild: 4769
In my wow and I'll BSOD w/ random drivers listed in the explanation and from time to time NO explanation!
Specs in sig, will post ANY info you need
Looks mem/cpu overclock related... relax your FSB a bit and test, or maybe loosen your mem timings.. that would be where I would start on that one. good luck!
strange thing is it seems to be happening more often
I'm trying to finish this instence in wow, but doubt I'll be able to... wierd cause it never used to crash so much, I've crashed 10 times in 10 minutes at least!
I played all last night w/o 1 crash...
NO FRICKEN WAY!
I set the timgings to 3.5
and dropped the FSB by 10
Now my PC won't even post, I reset the BIOS... NOTHING!
What!?!
hrm......... that sucks man. wow. sounds like you have have been seeing the symptoms of a dying component... try pulling one of the ram modules, try each one by itself. Does your mobo have a "failsafe" mode? try leaving it on, even though it will not post, for about 10 or 15 mins... my MSI neo4 would sometimes not clear its bios when I hit the clear button, and I would have to wait for it to go into "failsafe mode". but maybe try pulling the memory modules and trying them by them selves..
Yanked out Sound Card, no change
Yanked out one of my two ram sticks.... and! I get a beep out of my PC every second or so... still no screen showing
edit: #1
Took ram stick from slot 4, put it slot 1 = No beeps
Took ram stick from slot 1, put in slot 2 = No beeps
edit: #2
Took ram stick B (the one left out of edit #1's trails), put in slot 1 = Constant beeps and monitors display, "BIOS ROM checksum error, keyboard error or no keyboard present, Drive A error. System halt"
notes I have no floppy drive... and this RAM stick A didn't produce this result.
edit: #3 - out of curiosity
Took RAM stick A, put in slot 2, took RAM stick B, put in slot 1 = produces same results as those in edit #2.
Going on...
The only time I ever had errors like that on WoW was when I overclocked a system too much or had mem timings too tight... oh and when my 80GB hard drive started to develop bad sectors that happened also, but I already knew it was dieing so I could identify the cause.
By the way, my system was stable in other games when OCing, but as soon as a dropped the OC down the crashes went away.
Left my PC on since my last post, maybe 5 or so minutes, nothing yet...
HOLY CRAP NO!!!!!
MY RAM = DEAD!
How did this happen?
I dropped some ram from this PC in my other one and bam! works!
Damnit!
GSkill, they have good return policies right?
Should I just buy another 1GB of it while I wait and then just have 2GB?
Problem is I bought my ram from ozzieng and he's "On Vacation" so I'll have to wait a while to get the "Invoice # I need to return the ram" didn't realize I needed that info, figured what I needed was on the plastic box...
Or should I do.... what?
Anyone in the Apopka/Orlando, Florida area that can sell me some decent ram?
Thanks everyone!
Sad day today was...
Was going to be a great day in WoW, but it ended tragicly!
wow - that sucks man. I had a feeling it was memory related... I guess that's why I was mentioning the ram shuffle... good thing you had another pc to test parts with... I thought maybe you were posting from a lappy or something... Does you memory have any sort of warranty? You could always call GSkill and ask. Can't hurt. We're you running it way out of spec? Hrm.. well, check the ForSaleForTrade forum for some deals. There are always peeps there selling goods.
http://www.hardforum.com/forumdisplay.php?f=17
