dfi lanparty ut nf3 250
Expo
why can't i find any drivers for this board. searchin up and down websites and i can't get it to work.
really impatient. download the driver on flash transfer to the computer can't get the driver to boot all the way freezes and i give up. anyone help me out here?
specs:
dfi lanparty ut nf3 250gb
amd 3700+
2x512mb pqi
7800gs oc
200gb WD
cheap dvd reader/writer
i looked all over google. i tried looking for the nf3 and i got different versions. i tried one then BOOM instant kill on hdd. had to reinstall OS and again i will try with your links.
attempt #2
its a pain in the butt finding drivers for the board.. but they are there.. i have the same motherboard.. i use windows 7 on it but never tried vista.. you should be able to use the windows xp drivers.. but vista its self should be able to automaticly find the drivers.. thats what i did with windows 7
I thought you couldn't boot from this board stably Expo? How did you manage to get to driver installs when you couldn't even POST before?
no it posted before but then its being picky about the hdd now. so i had to use my other setup for it to be found and then swap back to the dfi to see if i was crazy or not. it finds it but makes me constant restart in order for it to be found.
motherboard or ide hdd?
trying to reinstall OS once again cause i fell asleep last night.
