DFI LanParty SLI-DR
LionKinG88
Hi,
I got the DFI LanParty SLI-DR a few weeks ago and a 7800GTX video card.
But as u may heard the 7800GTX is a big card, so it covers 2 of my SATA ports :confused:
What should or could I do now?
Is it just to choose another SATA port ?
I have had many problems with the new mobo's, imo theyre all pretty small and r giving me problems :p
Well, unless you have more than 6 SATA devices, can't you just use the other ports?
www.dfi-street.com
Make sure to read the rules, create a sig and put your location in.
You will find tons of information to assist you with your problem. :D
yea--just get a tat of DFI-street--send in the enrolement fee and remember DFI street knows all--even if your setup is working with un aproved parts--it ain't working ?-WTF--??--LOL
its DFI way or the high-way! you better paint that box the approved yellow and brown--but you have to get special paint from dfi-street. DFI makes no mistakes--it's all your fault if the MB ain't stable--!--LOL
i would look here for more reliable infi --the DFI street deal is just a bunch of !!!!!!WannabesOnCrack! :eek: LOL
http://www.rhcf.com/
The Rebels Haven Computer Forum Main Page
My 7800GTX KO Edition covers 2 of my SATA ports too, but I dont have the DR, only the D so I dont have the SI SATA controller.
So what I did is Plug in my 2 Raptors to the SATA1 and SATA2 that are free, and my 250 SATA Drive into SATA4 Then Plugged in the 7800 and the end of the card sits on top of the plastic end of my SATA CAble holding it down very tight, but the card is in, and the cable isnt going anywhere, and so far, I have no problems. But thats it for drives for me unless I get a Controller card.
