DFI lanparty nforce 3 driver install problem
eNforcer
Well when I install the nforce drivers and restart it hangs at the windows loading screen
Only way to get back in to use 'use last config that worked' option
Safe mode doesn't even work
Also when I go into the device manager the 'sm bus' bit has the question mark on it, so I try installing it manually but it says 'access denied'
It's not a permissions problem, fresh install and I am the admin
2800+ a64
winxp sp1a, (sp2 is doing the same thing)
