DFI Lanparty nF3 temp probs!
g33zy
Goes Down Easy
I am tryin to use MBM to check up on the sys info but after I install it, restart the comp, everytime i try to run it the comp crashes. I don't know if its becase I don't see the nF3 on the list so I just used the nForce Ultra?? or something that looked close to what I have. Maybe I am using the wrong setup, idk. Or is there another prog that i can use that might do the same thing? Ideally I just want to have the temps displayed in teh sys tray when i turn the prog on and it would be nice if it could keep a log of the tems so i can check after i finish gaming. any ideas?
Well just to let you guys know if anyone is interested :(....
I fixed the problem. With a DFI nF3 and up board you have to insally the prog, cancel the automatic motherboard selection and do everything manually (pain in the a$$)
To my delight there are still some good people in the world and i found someone who did it already and saved the settings, if anyone wants them ask and i'll give you, i just can't be bothered to go searching for them again now. The only thing that we still are working out is how to display the GPU temps in MBM5 on a nVidia card. It works on ATi cards but not on nVidia....
