DFI LanParty NF2 Ultra B Problems
Psycho
Personally love the board itself but having some major problems getting the hard drives to boot. Now i have Two Hard drives in there.. One running XP home and one running XP pro. Neither will boot. I tried reinstalling the OS on each of them.. Nada... After it installs some files.. It just goes into a loop and wants to boot from the CD again. Suggestions?
psycho please check the BIOS and make sure the hdd is set to LBA not CHS (bioses have a knack of setting hdd's to CHS by default).
also make sure hdd Block mode is enabled.
one more thing, check your jumpers to make sure they are correct. hdd's like WD do this if they are the only drive on the channel and have a jumper on (they need no jumpers if they are the only drive)
also swap IDE cables just to make sure =)
if this doesnt help, please list system specs so i have a better idea of what is in your machine =)
Angry,
Tried that to no avail. I honestly have no idea what the problem can be. System specs are as follows
Thermaltake case
DFI LANparty MB
Athlon XP 3000+
2 X 512MB Sticks of PC3500 Hyper X Ram
120MB WD 8Meg Cache 7200rpm Hard drive
550W True Power Antec Power Supply
Radeon 9800XT
Hopefully we can get this problem cured within a day or two.
Thanks Again
