DFI Lanparty: How to boot into memtest86?
spotpuff
I just recently got a DFI Lanparty UT NForce4 Ultra-D. I am using Bios 3/10/05, but I cannot for the life of me find the "boot into memtest86" option that every review site keeps talking about. In terms of boot options, I see the standard removable/cd/hdd/nvidia boot age, none of which boots into memtest 86. I've also looked into other areas but can't find it.
Can someone point me in the right direction in terms of getting this board to boot into memtest 86?
I was unaware that this board had this feature? I have the same one and I have never heard of or seen that feature supported on this board... maybe there is a hacked BIOS that adds this option? Ask around on dfi-street.com too.
I gained this option when I changed to the 5/10 bios, the 6/18 should have it as well. It is a bios option that says "boot memtest" or something along those lines, it is built into the bios revision, and boots from the CMOS.
Yup, its in genie bios options. Set it to enable. Turn it off when you want to get back into windows. Make sure you have the latest bios.
