DFI Lanparty choosing troubles.
acameron_56
Hey everyone, my question is as follows. Currently I own a EVGA 680i (A1 I think) and its not overclocking my Q6600 very well. So I want to get a mobo that does oc very well...and since I really like to get every possible once out of my parts, I was leaning towards a DFI board. Now here's my real issue, I can't choose between the LP Dk P35, LP LT P35 or the LP LT X38. What will I be getting with the LT P35 and LT X38 that merits spending more money on them then the Dk. I do not plan to crossfire, as I use a 8800 gts. Initially I was leaning to the LT P35 because it fit my needs pretty well, I think anyways. Then I thought that I would like to have a futureproof board so I'd wait it out and get a LT X38. But then a third thought occured to me...should I get a good board (Dk) for cheap that isn't exactly as futureproof as I'd like, and wait for a new killer board to come out? I only have air cooling (even though its really good for air) ,so I probly wouldn't be able to go too high with my oc's either. Anyways let me know!
Cheers
O and btw, if anyone knows of anybody who has one of these board to sell, or anybody who might want to buy my existing mobo let me know of that too :^), as I am currently sub 50 posts :(
I went with the LT x38. Its the best bourt out of the batch and its not dumbed down.
Newegg and NCIX both have the LT x38 in stock right now for 250(Egg) and 265(NCIX)
you can get the DK and LT X38s and the LT P35 at Motherboardpro.com.
you can get the DK P35 at newegg or ncixus
If you want a future proof board but aren't going to crossfire ever, you should go with the DK X38.
Why the DK? the DK is a dumbed down board... it has less SATA ports, Diff Bios Chips, Worse cooling, and other stuff. Go with the LT, newegg has it for 250.
I wouldn't call it dumbed down, besides the vdroop control present on the UT, it's Bios has all the same features. The only difference are the slots (no crossfire--1 pcie slot), SATA ports, and the cooling. If you are using first party cooling then maybe consider the LT or UT, although I know one or both of them have enormous NB coolers that might get in the way of your cpu cooler (if you go aftermarket).
I guess it's up to you, look at the features and decide what you need. If you need 8x SATA or crossfire support, step it up.
Thanks for the insight :). So I guess it really comes down to which is the best deal moneywise. The LT P35 for 190 from motherboardpro, the Dk X38 for 215 from motherboardpro, the Dk P35 for 155 from Nxsource, or the LT X38 for 260, if motherboardpro can get them in stock. Those do not include shipping though, and as I live in Canada, I'm not even sure i could get the mobos from motherboardpro and the shipping might be expensive. I'm currently looking into that.
That's the first place I checked, but was rather dissapointed that they didn't have all of them and that the ones they had were rather expensive comparitively anyways
Ok, so I think its boiled down to the Dk X38 for $230, plus the risk of paying more at the border, or the Dk P35 for $174. Right now I am very much leaning towards the P35 since I do not plan on upgrading to DDR3 ram anytime soon and I won't be using crossfire...is there anything else that I am not aware of that differentiates the X38 from the P35?
ya, but I was refering to the disappointment that they don't have the other models I was talking about.
Check pictures whether it'll fit. That cooler probably won't be much better than the stock one, as it is pure aluminum and fanless.
I'd just go with the stock one as it isn't bad (if you are air cooling), and maybe orient a case fan towards and and the mosfet heatsinks. Your cpu cooler can also push air over them if you orient it that way. What will you be using for cpu cooler?
Later in that article the last tall Zalman and the Blue Ice Pro look pretty good.
I was thinking of getting the Lan Party DK-X38 rather than the LT X38-TR2, I read a lot of good things about the LT X38-TR2, but is the DK-X38 going to OC just as well? I'd like to try and avoid spending 250 for the other board (I am going Crossfire)
Ya nvm on the mofset because I have a CNPS 9500...I had a momentary mental laps :(. Anyways I would agree that the thermalright does look the best, but it costs $18 whereas the other one only costs $8. So you don't think that it would benefit me all that much? I would already have a fan blowing air directly onto the northbridge...so i'm not too worried, I just thought that if I were to order a heatsink I would do so at the same time as the mobo to save on shipping :). Btw I am pretty sure now that I will be getting the Dk P35, I just need to figure out where to sell my 680i first.
I checked DFI site and from what i can get from there is that both boards, the X38 LT and the X38 DK both support crossfire...plz correct me if I'm wrong.....
There is little to no benefit in overclocking capability between the DK and LT series. The LT has improved features -- more sata, more pci-e slots, crossifre, etc..
The only possible OC difference would arise from different cooling on the northbridges.
In the two you listed, check reviews/comparisons of the X38 and P35 chipsets. I'm pretty sure the X38 is solid, if you don't need the LT's features the DK X38 would probably be the better.
Btw Astyler, if I do get the DK P35, should I worry about getting some aftermarket northbridge cooling or a mosfet cooler? And is this very much space to install them? For instance would the http://www.madshrimps.be/?action=getarticle&number=2&artpage=1972&articID=473 fit?
I own a DK P35 and with a E8400 at 4GHz (8x500) the mosfets are actually only warm. PWM at load never gets over 50. My northbridge is warm though, but doesn't inhibit my OCs. I've gone up to 525FSB stable on this board, and didn't try higher. OC'ing options are plentiful. I wouldn't worry about aftermarket cooling on the northbridge. The DK P35 boards have an annoying sticker that says warranty void if removed between the board and the Northbridge cooler, so using aftermarket cooling will void the warranty.
If you have no need to a multi-GPU setup then consider the DK series. It will save you a buck or two. The X38 has dual PCIe x16 slots, while the P35 doesn't. I generally believe that the P35s are clocking higher than the X38s. Performance clock for clock are similar between the two chipsets.
thx flexion, now my mind is made up for sure. Just need to wait till I can get 50 posts to sell my 680i :).
Why X38? Really think 2 cards is going to be worth it? Crossfire does scale a bit better, but performance per dollar, is still pretty dumpy for the cost involved.
Apparently I need reading comprehension practice...lol.
I thought you were pulling the trigger on X38. :p
The X38 does look pretty nice. The chipset just doesn't offer much more than P35.
If it offered sli over the P35 then I would probably opt for it, but crossfire is just not tempting to me at all lol.
Guys, I didn't miss the X38 having dual x16 slots! Sheesh.
His crossfire confusion was due to my comment, I failed to clarify
"LT's advantages over DK being blah blah crossfire blah"
to mean between the P35 boards.
Also, I heard said sticker is no longer on these boards, but I cannot confirm the validity of this claim.
O btw, the Board is UV sensitive right?
Yes, the board is UV sensitive. It's a spartan board. I had to put in an extra raid controller, to run additional HDDs. It overclocks really well, and I haven't had a single BSOD yet.
Apparently, there's a review by a guy called windwithme somewhere. It's at least on six different forum sites. He claims that the 4phase part analog PWM is actually superior to an 8 or 6 phase all digital PWM. I don't know, because I'm not an electrical engineer, but this board is more stable in OC'ing compared to a Gigabyte P35 DS3R that I had before. I do miss the feature rich Gigabyte though, but there wasn't anything I couldn't add via the extra PCI slots available.
Regarding dual GPUs, there's a war going on now between the green and red team in the midrange and value market. You can get powerful GPUs at or below $300, there's hardly any reason to get a multi GPU setup unless you're running resolutions above 1900 x 1200. If you do you could always get 3870x2 in that one PCIe slot and save some space.
If you never plan to Crossfire, I'd go with the cheaper LP LT P35. It's only $50-60 cheaper than the X38, so I'd go for the X38 simple because you might Crossfire. :p
Consider this - when's the last time you upgraded your CPU, but not your mobo? I don't think I've kept my mobo since going from a 2100+ to XP-M...that's 2003. So recently - no. Between P35 vs. x38, I saw no reason to use XF. That gives me 0 motivation to spend money on X38. P35 also OCs just fine, and I had no reason to use a heatpipe.
Based on that thought process I went with the LT P35.
