DFI lan party ultra-D boot issues...
baltour
The sucker keeps cold booting. Then when i clear cmos, it'll get me to point to where i chose safe mode or normal windows. after choosing, it reboots after that.
wtf?
I'm using a raptor that was previously raided by the other user, does this have any effect?
Try reinstalling windows, and remove any overclock if you have one.
DFI board
Seasonic S12 600w psu
2x512 kingston ram
X800 GTO
Opteron 148 2.2 ghz
36gb raptor hd
I get a syntax error after i run data eraser, and try to setup windows.
Now i got a hardware problem detected, and wont even try to install windows.
run memtest (it's in the bios) try tests 5 and 8, see how long it lasts, I'm betting the DFI board isn't playing well with that kingston memory. Those boards were finicky at best with cheap ram, specially kingston. Get yourself some OCZ, mushkin, g skills.
