dfi infinity vs. abit nf7-s
Does the Infinity have coax in or an optical in bracket? I need optical in for my PS2 so I might have to get the Abit board instead. :(
AUDIO
Realtek ALC650
AC'97 2.2 S/PDIF extension compliant codec
Supports Microsoft® DirectSound/DirectSound 3D
AC’97 supported with full duplex, independent sample rate converter for audio recording and playback
S/PDIF-in/out interface
6-channel audio output
Thanks GTP_driver, I had completely forgot about that. I think I might have a cable for it too. Although I still might have to bite the bullet and get an Audigy2 card in the long run.
Coax in. The Abit doesn't have anything in, only optical out except perhaps if there is a header onboard you could use if you have the appropriate connector.
