well it seems im having no luck at all with mobos lately. since chaintech screwed me over i overnighted a dfi infinity sli board and it will not overclock. even voltage changes wont save. it booted up the first time @250fsb. made it through windows install and then on the reboot went back to default settings and havent been able to change them since. i tried using the ntune utility to overclock as well and every time the system just locks up even bumping it up 5mhz. im thinking i should just quick rma this board and get the lanparty instead. any suggestions?
amd64 3500 venice core
2x1gb mushkin enhanced pc4000
bfg 7800gt
maxtor 250gb sata
lite-on 16x dvd r/w
and yes ive updated the bios, which im not too happy about either. the system went from booting up in about 15 seconds to 30 after the bios update.
bfg 7800gt
maxtor 250gb sata
lite-on 16x dvd r/w
