DFI BLOODIRON
hi guys i am trying to get my ram to run at 1200mhz they are the pc2-9200 1150mhz reapers, i know they are good for over 1200mhz i have upped the voltage to 2.3v but its still not stable, i have tried upping the NB volts but no good either ?
thanks in advance
Have you adjusted the timings? Aside from RAM and NB voltage, those are really the only settings that would affect the RAM's stability.
i am using 5.5.5.15.32 at the moment would increasing the timing to say 5.5.6.18.32 make them slower ?
Yes, it would make the RAM slightly slower, but it might help you hit 1200MHz. I wouldn't say it's worth it though. The small boost in RAM frequency won't make a difference to the overall performance of your system.
managed the 1200mhz but still a little unstable so backed off to 1000mhz @ 4.4.4.10 and just as fast and stable :::)))
Try increasing the trc value from 32 to 45 and see if that helps.
