DFI 790FX-M2R question.
lemans81
I have a dfi 790FX-M2R, and I cannot get my gskill hk's to work stabily at all. I have tried them stock = 4-4-3-5 2t 800, I tried them tighter 4-4-3-5 1t 800, I tried them as loose as 5-5-5-18 2t 667. When I run the cpu tests on orthos all is fine, if I do the ram I get errors just seconds into it. They ran in my EVGA 590sli board at 4-4-3-5 2t 950mhz 2.3v without issue. I have also had them run 4-4-3-5 1t 820mhz and 5-5-5-12 2t 1009mhz, and pass with that old evga. I pulled them out and ran them in several boards with no stability issues what-so-ever. I haven't run memtest yet because I find it a pain, but I know I need to do it. Odd though that they are fine in the 3 other boards I put them in, but the dfi is a no go. Anyone have any clue if there is a compatibility issue?
Try A) nudging up the HHT and Chipset voltages one step. And B) set each value manually. I had better stability when I set the HTT, Memory, and CPU frequencies manually. Hope that helps, and good luck.
for what its worth here is a link to the recommended ram for the 790fx-m2r.
LINK
i have a 790fx-m2rs that im waiting to build once i get my processor. might want to ask over at DFI Club to see if anyone has had any issues with the
specific model of RAM that you are running.
Makes me laugh, guess dfi forgot to pay for the ole website....because now its a generic search site.
