DFI 680i LT Announced
... DFI LANPARTY UT NF680i LT SLI-T2R. Despite the 'LT' designation, the specs are looking pretty full.
It uses the 680i LT chipset, so uhm... the specs look about as full as any other 680i LT chipset motherboard might look :), but yeah - that's pretty decent.
Well Sparkles, the 680i LT chipset originally is speced at only 2x16 PCI-E (DFI's has a third running at elec. x8), 1x Gigabit ethernet vs. DFI's 2x Vitesse, hence Dualnet teaming etc. since it's being marketed towars gamers, 2x PCI vs. DFI's 3. There may be something else I didn't see, but it does seem as if DFI has made a decent attempt at closing the gaps between the 680i LT and its older brother.
"Sparkles"? Is that supposed to be an insult or something? :rolleyes:
It's either a 680i LT chipset, or it's not. If it is, then other (non-reference) board manufactures can provide the same functionality, no? If it's not, then well... they haven't labeled it correctly (like ASUS labeling thier 'Plus' board a 650i, when it's clearly not).
If you look at nVidia's spec sheet for the 680i LT chipset, you'll see that it has 16, 16, 8, 1, 1, 1, 1, 1, 1 PCI-E lanes (same as the 680i). It also has 2 ethernet connections and in fact in all other ways is the same as the 680i chipset - the one difference being lower-rated memory support. My guess is that the 680i LT chipsets are just the un-binned 680i chips, so they are sold cheaper.
Obviously, nVidia has (artificially) introduced further spec reductions in the reference boards, to help save costs and make a more pronounced distinction between the chipsets, but any manufacturer using thier own design could add all those other features back in (as DFI has done). Time will tell, I guess.
Anyway, as I mentioned, I agree that the DFI board does look feature-packed, so the real question will be how well it performs and at what price-point. They are basically providing a 680i board (feature-wise), but with a chipset that costs them less... if they can pass those savings along to the consumer and still perform well, it'll be a nice alternative to a 680i board.
Well, I'd read elsewhere here in the [H]ardforums that DFI's MSRP is around $220, which doesn't help us out much if it were true.
