Developer claims FXAA + MSAA is the wrong way
ljbade
A while ago I read an interesting article from the NVIDIA FXAA inventor, Timothy Lottes - http://timothylottes.blogspot.de/2012/10/skip-msaafxaa-instead-use.html
In the article he shows that using FXAA + MSAA is the wrong thing for game developers to do, instead he reccomends games directly implement a version of TrSSAA.
FXAA was not designed to do a good job when applied over MSAA or other multi-sample techniques like TXAA. FXAA adds some rather bad artifacts in those cases.
I notice in the Warfighter review that the game uses FXAA + MSAA instead of the TrSSAA.
What are your views on this? I assume a game directly implementing TrSSAA should get better performance than the driver override due to the tweaking possible.
Should Battlefield 3 + Warfighter be patched for TrSSAA support?
I would love for games to have that.
But:
Nowaways, transparent textures aren't the only source of aliasing. Specular aliasing is a big problem that is not solved by TrSSAA. Either you go FXAA/MLAA/TXAA (either doesn't work well or is blurry in case of the latter) or you use OGSSAA (bad image quality/performance ratio) or SGSSAA.
Ingame-SGSSAA, maybe applied to select objects and portions of the image would be the best thing imo. MSAA for the rest.
But:
The technique he describes could also be used for specular AA, it would result in a bigger performance hit though. Basically all surfaced with specular aliasing would be super sampled too, but clever programming could reduce this to only the edge pixels.
EDIT: But I don't see why any game using DX11 does not add this since it would only require a few more lines of code.
Good to know.
Why? Budget issues, laziness, devs don't know/care about aliasing, it doesn't benefit consoles etc.
