Determine if all PC components work 'together' or not...
ahmadka
Hi everyone.... I just wanted to find out, if there is there any way to see if all my PC components perform in step...i.e., see if any one component does not slow the entire processing down....
I am asking this because I think my rig's CPU is slowing down my PC when I play games...I just want to see if this is true or not...To see if the CPU performs relatively slower than the other components, e.g. graphics card, hard drive, etc...
Also, I dont mean to say that I want to determine if only the CPU is a limiting factor (if at all)...I am asking about all PC components in general..
Maybe there is some software, which cud probably run in the background monitoring the PC's stats, while I play a game...and then maybe I can take some readings from that software to see if all my PC's parts are performing together, or if something specific is slowing everything else down...
Thanx in advance :)
Your GPU is the bottleneck, consider upgrading to the 8800GT.
hm...dont you think that the CPU is being the bottleneck here ? at least, thats what I think...I mean, 1.8Ghz only ?
OC it! Mine can reach 3Ghz! but it gets so hot, so I leave it at 2.6Ghz. ;) see sig.
Also, why did you buy an opteron if you weren't planning on OC'ing it? lol.
no, i did get an opteron cuz i wanted to OC it. I just wanted to wait till the time when I really need the extra speed. This is so because I havent OC ever before :p....Anyways, I think that time to finally OC this Opty has arrived :D...
So, is the CPU the bottleneck then ?
Open up task manager and browse to the "Performance" tab. Make sure task manager is set to stay on top of all windows, then enter your game and keep an eye on the graphs.
If the CPU graph hits the top of the graph and stays there, the CPU is the bottleneck.
If the Page File Usage reaches or exceeds the amount of RAM in your PC, your memory is the bottleneck.
If neither of these conditions occurs then your GPU is the likely bottleneck.
hmm...nice idea...i think i might try that :D......but dont you think the screen might flicker or something if the task manager is above a heavy game like crysis (demo) or UT3 ?
Maybe RivaTuner has this same functionality...monitor the stats, which I can see later on..
If you're playing Crysis....I think the game's gonna lag no matter what hardware you have....that thing is devastating on hardware if you run it at anything above 1024x768.
But yes, something that logs your performance in the background would definitely be better. I'm pretty sure I could write you up a small vb or java script that would do that if you'd like.
