T
troyquigley
Guest
i need to find a utility that monitors bandwidth used by each workstation.
so i can see which computers are hitting the server the hardest.
i really ONLY need it to check bandwidth usage for each workstation. i dont really
need anything fancy at all. the simpler the better.
and i want the utility to be installed on only 1 workstation and that being able to watch the bandwidth of all the OTHER workstations. i do not want to install the utility on EVERY workstation.
