Desktop off-center
Jarlaxle
My old XFX 8800GT died and they shipped me a new one. I physically installed it, hooked it up to the same monitor I was using before, and the entire screen is shifted to the left about 1-1.5 inches and up about 0.25 - 0.5 inches.
First, I uninstalled the Nvidia drivers, rebooted into Safe Mode, ran Driver Cleaner, booted normally, grabbed and installed the latest Nvidia drivers, rebooted, no luck. Did the same thing as above with the older drivers on the disk they sent with the new card. No luck. Tried again with the latest Omega drivers. No luck. If I change to lower resolutions (1900x1200 default) the issue still persists. If I remove the drivers, everything is fine (aside from obviously not being able to play games.)
Tried both DVI ports in the back of the card, same thing. However, if I use the analog cable from the monitor and use a vga-to-dvi adapter, it works fine. I'll probably try component soon.
Tried messing around with my monitor settings (LG L246WP 24" WS) but cannot "push" the screen to the right as those controls are disabled for HDMI/DVI. Same for everything I looked at in the Nvidia control panel. I've uninstalled and re-installed the lasted drivers for my monitor. I used the controls on the monitor to set it to factory defaults.
I installed Power Strip and it lets me push the screen to the right some, but not enough. Even if I do that, shortly after I do it, the screen begins to blink rapidly. This happens whenever I change pretty much any of the settings in the "Advanced Timing Options" settings. I've tried making random changes in both the Power Strip and Nvidia Control panel to many things, including timing settings (Sync Width, Sync polarity, etc.,) with very little success. Once I did change one of those settings in Power Strip and it looked like it was going to fix it, but the blinking started happening again and I was unable to replicate it.
Any ideas? Sorry for the long post, but I was trying to be as thorough as possible. The next thing I was going to try was taking the card to a friend's house to see if I could replicate the problem there.
That happened to a computer of mine once, but the problem was my monitor, and I found the auto-adjust feature on the monitor and pressed it, and then everything was OK again.
If I read your post right, your monitor cable you are connecting to your computer is DVI? The reason why those controls are disabled is because DVI reproduces a "digitally perfect" image, and thus, color options and all those other neat stuff are disabled - because it's not needed to modify.
Is the screen shifted during POST and BIOS?
Mine has that, but only pops up a screen which says what mode I'm in (ie, 1080i.)
Yeah, I didn't know that until this happened. Learn something new every day. :p
Nope. Even during the "Loading Windows" screen it's fine. Also, if I boot into Safe Mode, the screen is just where it needs to be. The only time it happens is when I boot normally and have the GPU drivers installed.
Try some different drivers.
I have. I tried the newest ones (177.79) and some old ones that came with the original card (167.26) with no change. I even tried the newest Omega drivers (2.169.21.)
Going to take it to a friend's house today to test for sure if it's the card or not.
Does it happen with all resolutions or just when you are at certain resolutions?
When I had the problem it would only happen on the native resolution of the monitor... but if I turned the resolution down, it would fit properly.
I had a similar problem with my Westy 37" and a ATI 4870.. The fix was to disable the "Reduce DVI Frequency" option in the control panel. I think this is an option in nVidia drivers too.
I had problems with my LG too when I got my 9800gtx. It might be the nVidia drivers. Try this.
WOOOOOOT!!! That did it! MANY thanks! I've been tearing my hair out over this for the last week.
How did you ever stumble upon that? Any clue as to why it worked fine with my old 8800GT but not this one? Now I'm just very curious of how it happened in the first place.
Glad you worked it out! I have no idea why it didnt work with ur new 8800gt, but yea I was having trouble myself and someone on the board gave me the link to the page. Enjoy.
