Desktop build, help please
Sengirr
Configured this build in a cart on newegg using various combo deals and the cheapest utility parts I could find. Please rate or speak up if there's any compatibility issues or low quality parts included.
Case and Power Supply -
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.461802
CPU and Video Card -
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.459277
Motherboard and Memory -
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.481499
Hard Drive -
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534
The total price is $817 after shipping, is this a pretty good price for the performance I would get for gaming (SC2, Diablo 3) and ample opportunity for future upgrades?
Thanks
Gaming Starcraft 2 and Diablo 3 for sure, and then school, web browsing
Under $1000, including tax and shipping
3) Where do you live?
Houston, TX
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Listed in my links
Samsung monitor, and basic speakers
6) Will you be overclocking?
nope
20" Samsung
within the week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Crossfire
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
going to get 64-bit Windows 7 basic
Hard Drive -
Thanks
Not that good dude. Not that good. $829 build with Win 7 64bit
Microsoft Windows 7 Home Premium 64-bit + Coolermaster RC 692 for $159.98 w/free shipping
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437504.11-119-215
OCZ Special Ops Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 + AMD Phenom II X4 955 for $224.98 ($20 MIR on RAM) w/free shipping
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.456646
Antec NEO ECO 620C 620W for $69.99 ($20 MIR) w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s USB 3.0 for $99.99 ($10 MIR) w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275
GIGABYTE GV-N460OC-768I GeForce GTX 460 (Fermi) 768MB for $199.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125334
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
LITE-ON 24x sata dvd for $19.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Total: $829.91 w/shipping $50 in MIR
