Desktop Build Assistance
forkedt
Not having owned a desktop in years (I choose to sacrifice the performance for the portability of laptops) I have been recently asked to help my father build a new one.
He likes this: http://www.bestbuy.com/site/olspage.jsp?skuId=8808294&type=product&id=1206142366661
And if I can I would prefer to build him a better desktop for the same or less. He needs it for graphic editing (works with very large photos and videos and does a lot of heavy work with them).
The Q&A:
Graphic Editing and Creation
Prefer to keep it at or under $1,000.
3) Where do you live?
North Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything* but the monitor
*I have a case but it may or may not be suitable depending on the suggestions I receive.
6) Will you be overclocking?
Probably not, but that depends on the performance of it stock.
Unsure (he didnt specify, and I forgot to ask)
As soon as I pick the parts and get them delivered.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Not sure, probably Firewire for any equipment he uses that may need it. Possibly RAID but I may just put a 2nd drive in and let him copy backups to it as needed if it's cheaper.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
Thanks!
depending on what case you have would help us see if you should upgrade. here's a basic build that will GREATLY outperform that dell at bestbuy.
wd 1tb black http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
6gb skill 1600 ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
corsair 550w psu + evga gtx 260 video card (not sure how powerful of graphics card you actually need)http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.179670
i7 920 + asus p6t http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.181245
add a decent dvd burner for $25 and it comes out right around $1000.
Thanks! I've looked into the parts you recommended and they probably wont work with my case, any other thoughts on a solid case for housing them? It doesn't need to light up or anything fancy, but does need to secure everything soundly as he may need to transport it with him from time to time.
Any modern case that relies on 80mm case fans is NOT a good case. Get one of the newer Centurions -- the 532, 534, 590, or 690.
But a fully loaded ATX mid-tower case can weigh anywhere between 15 lbs and 40+ lbs. forkedt, which case do you already have?
