Designing a NAS - Any suggestions/comments?
Zero1
Wow, long time, no visit.
Not so long ago I got the networking bug. At first networking was a bit of a mystery to me and although I'm pretty savvy with most stuff, networking always let me down. Since I took the plunge and got into networking, I'm loving it. I'm loving the learning process and I'm loving the benefits (such as printing wirelessly to a wired laser printer, sharing media on my Xbox360 etc.)
Well my situation is I have anything up to 4 machines I use (depends whether I need access from my mini-itx, a laptop or a more powerful machine), plus another 3 devices that are capable of sharing media (Xbox360, KiSS 1600 DVD/media player and a Nokia N96). I thought it was high time I took my files from the 3 machines I use most and consolidated them in one place so they are accessible anywhere at any time. NAS seems to offer what I need.
Now obviously I need a NAS box. I'm open to suggestions for the NAS software, but initially I intend to use FreeNAS as it seems pretty simple and lightweight. I'd like a software that can set access restrictions by MAC address or IP address if anyone knows of one, so I'm open to suggestions.
The criteria for my NAS (which is probably the most common) is that it's quiet and relatively low power consumption. I don't know what to expect with throughput, and obviously that will be dictated with the hardware, but if I'm using a 2 disk RAID 1 array, I hope for around 40MB/s + (In an ideal world, 60MB/s, but access speed is actually more important than throughput I would say).
If I were to use some spare hardware I've got, then at my disposal I have:
  • AMCC/3Ware Escalade 9500s-4LP PCI-X RAID card (also works on standard PCI)
  • AMD Duron 750MHz (will O/C to 900MHz fine), + Socket A motherboard 100/120MHz FSB + 320MB SD-RAM
  • Socket A motherboard 200-230MHz FSB (originally took an Athlon XP 2600 but the CPU is dead) + 1GB PC3200 DDR-RAM
  • 2x 80GB Western Digital Caviar RAID Edition (8MB Cache each)
Now although that list is very hit and miss, my two viable paths are a Duron 750MHz based system with 320MB RAM, or an Athlon XP based system (no particular CPU speed) with 1GB RAM. My question is would the Athlon XP system be overkill for what it is? Essentially I will be storing documents and there won't be a great deal of concurrent access. 2 systems would be about average. How about the 3Ware RAID Card? Is that overkill for my intended purpose, and are there any cheaper but just as good alternatives? Finally, in a NAS environment, what is usually the most beneficial in terms of an upgrade, faster CPU, more RAM, faster HDD? I guess some amount of caching goes on so I'm not sure.
I would also be in need of a small case and a quiet and/or efficient PSU, so I'd appreciate any suggestions. I'd also consider getting some new harddrives.
I know it's not really an excuse since I'm dealing with old technology anyway, but I haven't assembled a PC for around 3 years (and I've been out of the loop just as long)
Thanks guys, really appreciate your help.
Im not sure I can offer much advice, but i'll try. :)
Ive currently got a system not to much disimilar to the duron system that you mention. It works fine for the duties that you list although the new Intel Atom processor and motherboard consume alot less power than the duron does/will.
For the NAS software I use Debian etch with Webmin to control the Server side of it. It gives you lots of control over the system an is very easy to set up how you want to. FreeNAS was one alternative I tried but for some reason I never could get it working fully. (Probably due to me not spending enough time learning its full potential mind) There is also Openfiller I believe its called thats similar to FreeNAS.
The two hard drives you list seem to be quite small in size for a NAS box. I have 8*250GB in mine and im currently planning a new one with 6*640GB instead as ive filled that completely within 6 months of having it. Do I need all the stuff on it? No but its handy to have :)
Hope my rambling and thoughts are of some use to you...
Also the RAID card you have sounds quite nice. A little overkill maybe but if you have it you might aswell use it :)
Windows Home Server is another option, and you can use the older hardware. The OS is about $150. Does automated backups, remote logging in, super easy to expand, folder duplication. It's based on Server 2003.
