Designed to be Redesigned?
Screes
Logic supply has a range of cases they say can be modified however you want.
They have a few 1U enclosures that are 19" x 1.75" x 10" with dual expansion slots on a riser. I was thinking of asking them to shrink the width down to 13", and increase height to 3.5" and depth to 13". The only other change id want is a third expansion slot above the standard 2' and a blank front faceplate.
It looks like they might have a minimum order requirement of 100, but otherwise it seems like per unit it might be affordable.
What do you guys think?
http://www.logicsupply.com/products/mk100
http://www.logicsupply.com/q_and_a/designed_to_be_redesigned
They are local to me so if you can make them build a case I would be in for one lol. I actually applied to work for them but the bastards passed on me.
rackmounts...? :/
They don't have to be rack mounts, they say they can adjust any deminsions you want.
I just picked the rack mount case because it had the expansion slots on a riser the way i want them.
Ill try to remember to call them on Monday and ask for a quote.
