I'll try to make this a very simple question, as it is attached to a much larger project. (I'm not even sure if this is in the correct forum. It's kinda all over the place)
The Question:
What is the fickle and seemingly magical reasoning for when a GPO is applied versus when it's not? Does it matter if I format the system and reinstall? It does check and notice that all the applications it is supposed to have reinstalled aren't there, right?
UPDATE: I think I figured it out: There's a delay mechanism isn't there? A time-out? A delay before GPO is applied? Like after a format or something? How long is it? Or am I completely wrong?
(NOTE: I have set the system to 'wait for network' on boot, so it should be checking GPOs.)
The Background:
Right now I'm attempting to assign Office 2k3 to systems on a domain. There is only one system in a testbed OU with a software installation GPO assigned to it. Ignoring the permission issues I'm running into occasionally (I realized I needed to set permission based on computer, not users) and the problems slipstreaming SP3 into the AIP (I hope the install I'm doing now will fix that; I believe it was the short file names problem) I'd just like to know why the system seems to ignore the GPOs after a format...or whenever it feels like it.
I've dated women who are more consistent. I've got MSI that properly install, not being installed on the system, let alone the MSO install. This is typically after I reimage, or reinstall the system, and add it back to the domain. Do I need to remove them from AD, then add them back to the directory and move that system to the correct OU? Or am I simply doing something incredibly wrong?
I'm the kind of guy who will go through and learn something himself, researching the hell out of a subject, before asking questions. But this problem is too inconsistent for me to do that, so I'm asking for the help of those who have done this before me. I should just go and study for my MCSE already. I bet this is in there somewhere...
Thank you very much for your time and wisdom,
--Fox
Edit: SP3 slipstream worked! ^_^ Now if I could just get it to dependably install by itself...
The Question:
The Background:
--Fox
