Denon poa-s1 amplifiers
Jbort1984
I have 2 of these amp and finally have room to use them and power some subwoofers for my home theater room but dont know what kind of subs to get any suggestions. These are good down to 1 ohm.
Need much more information before anyone can give you any sort of helpful advice.
Room size, other equipment, listening habits etc.
mostly movies and music once in a while. i listen to everything when it comes to music.
room size in 26ft long x 18ftwide x 10ft ceiling. For mains im using
fronts 2 pairs of paradigm titan monitor's
my center channel is a paradigm millenium trio 20
and millenium 30s for my rears
i was looking into 2x tcsound 18in woofers .
Using an Denon avr-8000 preamp
Denon poa-8200 for my rears
Denon poa-8300 or my fronts and center channel
those are nice amps but you would probably not have enough power on tap if you were looking to go with the LMS-R 18's, especially if you were thinking sealed. You are better off going to an official AV forum like avsforums.com and go their DIY section. Lots of discussion around DIY subs over there.
I have a pair of QSC-PLX 3602 these wont do 1ohm but will do 3600w at 4 ohm or 2800 at 8 ohm.
gonna head over to avsforums also thanks for the info
Hello, do you still have the amps?
heck of a necro reply to a user that hasnt been around for 5 years...
this post is from 2012. 14 years ago. Most likely they moved on...
I doubt the mods will provide contact information just because you want it.
I will not disagree but you never know... Sometimes someone comes back by accident... Thanks
Pretty sure they are dead and in someone's freezer who has a frozen meat fetish.
Last seen Dec 2021...... Plausible confirmation of proposed theory.
Try googling the alias or head to the avsforums.
