Denon AVR-X1300W Receiver $299
Discussion in '[H]ot|DEALS' started by prime2515102, Dec 27, 2017.
  1. prime2515102
    prime2515102 [H]ard|Gawd
    1,367
    Mar 3, 2003
  2. Riccochet
    Riccochet Necrodancer
    22,962
    Apr 11, 2007
    Unter Dog and prime2515102 like this.
  3. prime2515102
    1,367
    Mar 3, 2003
    I must say, this receiver sounds a LOT better than the Onkyo it replaced (TN-NR636). It's clearer, less harsh, and the soundstage seems more precise. Not too shabby at all for $300. I just needed something that can do HDR but better sound is a bonus.
  4. doz
    doz [H]ardness Supreme
    5,343
    Jun 16, 2009
    Dead on both links. Looking for one too ;/
  5. Trimlock
    Trimlock [H]ardForum Junkie
    14,522
    Sep 23, 2005
    These are great, good networking control and an app.
  6. geforce man
    geforce man [H]ard|Gawd
    1,040
    Jan 18, 2006
    picked this up, fantastic deal. Sounds great hooked up to my HT setup
  7. doz
    5,343
    Jun 16, 2009
    AVRX2400H is on sale @ Frys today only for $399 with code. Headed over in a bit to snag one.
  8. westrock2000
    westrock2000 [H]ardForum Junkie
    10,229
    Jun 3, 2005
    The 400 series (1400,2400,3400, etc) also allow for the Audyssey MultEQ Editor App which allows you to log in to the reciever and manually adjust a ton of the curves that the receiver comes up with during Audyssey auto set up. I just learned about this app last week and have not had a chance to mess with it. I have the Dayton OmniMic from PartExpress that would allow me to measure the frequency response. But something like REW would also work for less money (cost of a decent USB mic).
    EDIT: Looks like the 300 series also can use this per the Denon website.
    • AVR-X6300H
    • AVR-X4300H
    • AVR-X3300W
    • AVR-X2300W
    • AVR-X1300W
    Here is full list from the iTunes App
    Denon AV Receiver: AVR-X6300H, AVR-X4300H, AVR-X3300W, AVR-X2300W, AVR-X1300W, AVR-S920W, AVR-S720W, AVR-S730H, AVR-S930H, AVR-X1400H, AVR-X2400H, AVR-X3400H, AVR-X4400H, AVR-X6400H
    Marantz AV Receiver: AV7703, SR7011, SR6011, SR5011, NR1607, NR1608, SR5012, SR6012, SR7012, AV7704
  9. prime2515102
    1,367
    Mar 3, 2003
    Can the calibration mic that came with the receiver be used for that?
  10. Trimlock
    14,522
    Sep 23, 2005
    I think the included Omni mic is ment to be used with it.
  11. westrock2000
    10,229
    Jun 3, 2005
    With the normal built in Audyssey for sure. I’ll have to get back to you, but I’m guessing you need something external to measure the response. The initial curve is set by the included mic. I just don’t know about getting feedback to visually tweak the curve afterwards.
  12. Unter Dog
    Unter Dog [H]Lite
    80
    Apr 12, 2016
    Not to side track the thread, but i've bought a couple from Accessories4Less and have had a good experience.
  13. Riccochet
    22,962
    Apr 11, 2007
    Only place I buy home theater gear any more.
  14. Fleat
    Fleat Gawd
    892
    Jun 29, 2005
    I purchased a high end refurbished Marantz receiver from them and had problems with the HDMI connections cutting in and out. I found this in testing in the first week and contacted Accessories4Less and they blamed my theater's RedMere HDMI run which was around 25ft.
    I tried to explain that I also tested it with a 5ft run and saw the exact same issues, but they refused to exchange the receiver without me first buying an absurdly expensive cable from them that would "fix" the issue. I opted to not do that and instead had it repaired by Marantz which resolved the issue.
    I recently purchased anther receiver for my living room upstairs and I went with Costco instead. They are much easier to deal with if you encounter any problems.
  15. Unter Dog
    Unter Dog [H]Lite
    80
    Apr 12, 2016
    Shitty of them, wonder if you got a bad tech or their support is just bad on average.
  16. Fleat
    Fleat Gawd
    892
    Jun 29, 2005
    It was a combination of two different reps. The rest of the purchase process seemed okay, but I don't think I will personally be shopping with them again any time soon. Through that experience, I also found out that it was very difficult to find an authorized Marantz repair center in my area (within reasonable driving distance).
  17. 123Lanoix
    123Lanoix 2[H]4U
    3,588
    Nov 13, 2005
    I really want to upgrade from my onkyo 636 and been eying denon but i want to make sure this thing will last me a couple of years with the new standards coming out for 4k
  18. Unter Dog
    Unter Dog [H]Lite
    80
    Apr 12, 2016
    My Denon is like 4 yrs old and still getting software updates if that helps, no idea the model (I have guests so i cannot check in my basement).
  19. vegeta535
    vegeta535 [H]ard|Gawd
    1,336
    Jul 19, 2013
    Can't beat that kind of product support these days.
  20. munkle
    munkle [H]ardForum Junkie
    11,231
    Jan 16, 2005
    That's amazing! That comment may have just made me consider only getting Denon receivers. I have a pioneer receiver that never got an update after the newer model came out, and its definitely got some bugs. Occasionally it won't display video, or audio when you switch the input source. Turning it off and back on again fixes it.
  21. 123Lanoix
    123Lanoix 2[H]4U
    3,588
    Nov 13, 2005
    my next AV receiver is going to be a Denon since Onkyo dropped the Audessey calibration
  22. doz
    5,343
    Jun 16, 2009
    Didn't get the X2400 last week but picked up the X3400H from Fry's on Sunday.
    Very big upgrade to my 10 year old Denon but I will be using the old one in the garage now :D
  23. doz
    5,343
    Jun 16, 2009
