- Jan 2, 2003
http://www.usa.denon.com/ProductDetails/623.asp#
FEATURES
Availability
Finish Black and Silver
Equal Power Amplifiers 7ch
Power Output; Watts Per Channel 120
All Channels Rated @ 0.05 THD
All Channels Rated @ 0.08 THD
THX Ultra2-Certified
Low Impedance Drive Capability
High-Current/Discrete Amplifiers
Independent Power Supplies 4
Pure Audio Construction
Front Panel A/B Speaker Selector
Toroidal Power Transformer
Dynamic Discrete Surround Circuit D.D.S.C - D
Dolby Digital, dts and DSP Modes Analog Devices, HammerHead SHARC
Dolby Digital, dts and DSP Modes Texas Instruments Aureus
Processor(s) Bit Depth and Type 32-bit Floating Point
Dolby Pro Logic IIx with Cinema, Music, Game Modes
THX Post-Processing DPL (4.0), DPL2 Cinema, DD/DTS (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema
THX Ultra2 7.1 Cinema, Music and Game Modes
THX Surround EX Decoding
Dolby Digital Surround EX Decoding
dts ES Discrete 6.1 Decoding
dts ES Matrix 6.1 Decoding
dts Neo:6 Stereo-to-Surround Cinema and Music Modes
dts 96/24 5.1 for DVD-Video Processing
Dolby Headphone
HDCD Decoder
Auto Setup Calibration
Auto/Manual Room Equalization
Audyssey MultEqxt Room Eq. with up to eight position setup
Auto Setup Microphone Included/Type Y/Mold
AL24 Processing - All Channels AL24+
24-bit/192-kHz DACs Burr-Brown PCM-1791 2/8ch
24-bit/192-kHz DACs - Analog Devices
Analog-to-Digital Conversion - Bit Depth/Sampling Rate 24/192
Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250
True 24-bit/96-kHz Digital Input Capability
True 24-bit/192-kHz Digital Input Capability
Assignable Digital Inputs
Digital Input DENON Link 3rd (SACD Ready)
IEEE-1394 Digital Audio Input/Output
Digital Inputs: Coaxial 2
Digital Inputs: Optical 5
Digital Outputs: Optical 2
Digital to Analog REC Out
Analog Audio Inputs, Incl. Tuner 11
Phono Input
Source Function Renaming
Analog Record Outputs 3
Front Panel A/V Inputs w/Cover * Composite and S-Video x* with Optical
Video Conversion Composite to S-Video to Component
Video Conversion Composite to S-Video to Composite
Video Conversion Analog to HDMI
Built In Time Based Correction
DVI/HDMI Video Inputs Compatible with 1.1 Spec. Multi-Channel Audio 2 HDMI
HDMI Video Outputs 1
Composite Video Inputs
Composite Video Outputs 3
S-Video Inputs 7
S-Video Outputs 3
Component Video Inputs x Bandwidth - *Assignable 3x100
Component Video Outputs 1
Dual Surround Mode Spkr. Selector
Icon-Based On-Screen Display
Front Panel System Setup Control
Personal Memory Plus
System Setup/Surround Parameters Lockout
6-Ch. External Analog Input
8-Ch. External Analog Input
Audio Signal Delay (Sync. Audio with Video signal) By source
Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
Stereo/Direct Modes w/Pure Analog Path
5-Channel Stereo Mode
Video Game Mode
Wide Screen 7.1 Mode 17.1
Mono Movie Surround Mode
Rock Arena Surround Mode
Matrix Surround Mode
Jazz Club Surround Mode
Virtual Surround Mode For 2 Speakers/Headphones
Multi-Channel Stereo Mode 5/6/7/9
DSP Effect Modes 7
Auto Surround Mode (Analog or Digital Input Type)
Active Center Channel In All Surround Modes
Banana Plug Speaker Terminals, All Channels
Cinema EQ
Front A/B Speaker Selector
56 Station Auto-Preset Memory Tuning
Radio Data System (RDS)
XM Satellite Radio 'Connect and Play' Ready with optional antenna
Direct Function (Tone Bypass)
Volume Control Un-muting
Selectable Muting Levels (Full/-40/-20)
Video Select Control
RS-232 Port Third Party Remote Controllers
RJ-45 Ethernet Port Same Functionality as AVR-5805/4806
PC Setup and Control Capability
IR Serial Remote In/Out terminals
+12v Trigger Output - Assignable
Multi-Source/Multi-Zone (*Uses REC OUT) 3S/3Z
Pre-amp Outputs for Multi-Zone
High Pass Filter for Multi-Zone Outputs
Multi-Zone Pre-Amp Outputs Selectable Output Levels Zone 3 fixed
Discrete Multi-Zone Composite Video Output - *S-Video also Zone 2 Only
Discrete Remote Power On/Off, Source Selection and Volume for Main and Second/Third* Zones *
Discrete Remote Source Selection for Zone 3
Assignable Amplifier Configuration of Surround Back Channels x With Volume
Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back
Relay-Controlled Protection Circuits
Pre-Amp Outputs
Microprocessor User Re-set
Detachable Power Cord
Subwoofer Peak-Level Limiter
Pre-programmed (10 Devices) Glow Key Remote Control with Punch Through Commands
Pre-programmed/Learning EL Remote with Backlighting and Punch Through Commands All New Version
Weight: In Pounds TBA
Width (inches)
Height (inches) 6.7
Depth (inches) 16.9
FEATURES
Availability
Dolby Headphone
HDCD Decoder
Phono Input
S-Video Inputs 7
S-Video Outputs 3
Video Game Mode
DSP Effect Modes 7
Cinema EQ
Pre-Amp Outputs
Width (inches)
Height (inches) 6.7
Depth (inches) 16.9
