Denon AH-D950 padding
RedTalon19
unfortunatly, denon discontinued all of their headphones quite some time ago and this was all that i could find on thier site to give you guys some info on them. i want to keep these cans for a very very long time since they have i think great sound and they have such an amazingly low ohm rating (30) i can use them with my mp3 player that uses a single AAA battery and they still sound great.
Specs
these cans have always been uncomfortable after several hours of use because the pads arnt quite thick enough to hold them completly off my ears, pressing slightly down on them. this pressure through the years has worn through the thin layer of padding on the inside making them that much more uncomfortable (cant post pic now, camera left at school)
anyways i wanted to know if you guys had a simple solution to hopefully add more padding to raise the cans futher away from my head to eliminate them resting on my ears (i think i really only need 1/2") or if there is no simple, good looking solution for that... to replace the thin foam padding on the inside. any suggestions here are welcome.
i might just have to resort to the old duct tape fix. duct tape fixes everything.
