actompkins
- Jul 10, 2007
Thinking about getting a delta fan because of their high cfm.Has anyone here ever used a delta fan and just how loud are they?
I still have (but haven't used for a long time) a Delta 80mm fan that went on a SocketA Alpha cooler (back in the day). It was 8k RPM, and was about 60dB. I got it because it moved over 100CFM in an 80mm package. However, everyone but me hated it.
It's often not the turbulence, but the pitch of the noise. The loudest fan I ever had a was a 92mm Vantec Tornado, which put out 119CFM at 56dBA. Needless to say, it was relegated to a 7 volt line for the rest of its life
Another thing to remember is that not all decibal recordings are to be treated equally, and under almost no circumstances should they be used to compare noise between manufacturers.
Now if you really want to have fun with a Delta... this would be the one to get. If even Delta calls this one "Drastic"ally powerful, then you know you have something truly Godlike in your hands...
... Yes, that's 8,000RPM on a 92mm fan.
