JadedMaple
- Jan 4, 2005
What kind of motherboards do the new Dell Dimension 8400s have?
Thanks..
JadedMaple.
Thanks..
JadedMaple.
OwNjaH said:and the older dimension 4550? i want to transfer this computer to a new case.
I second that. Strip the system down to board and case, dump those two. Then get a decent case and new mobo. I know Dells.eighty8fierogt said:I had the 4550, and bought a Thermaltake case. No dice, mobo wont work. Unless you want to figure out all the wireing and maybe try to make it work good luck. Better off just buying a new board and useing your CPU if your on a budgit or a mobo and CPU combo. Just my $ .02
xyoufailmex said:Dells= waste of cash
Their RAM is cheap, as are the hard drives. Their LCD monitors are the only things worth anything. We have replaced either a hard drive or a CD-ROM drive on 12 out of 38 of our Dells at work.
`XSX` PC-Parts said:LMAO all the components are aftermarket manu. including their memory, aside from the power supplys & mobo's they are the same stuff newegg & others sell![]()
qdemn7 said:I second that. Strip the system down to board and case, dump those two. Then get a decent case and new mobo. I know Dells.
