So my aunt's friend has a Dell Dimension 4600C and some Dell monitor. My aunt asks me to look at it to see what's up with it because something's wrong with it.
I hooked everything up properly and turn it on. The hard drive spins and the power lamp turns on, but the monitor is in a power save mode (the power button is orange instead of green). I try pressing the menu button for the monitor but it says that the computer is in "Power Save mode" and to "Press any key or move the mouse." So I try that and nothing happens. I then try hooking up my monitor to it and it still doesn't work; my monitor says "No PC Signal." So obviously, there's something wrong with the computer...
Any ideas? The Dell site doesn't help at all and I haven't found anything on Google...
Edit: I'm able to turn it off. I've tried using Windows + L, Windows + Shift + L, and Windows + U + U.
I have no clue clue if Windows + Shift + L does anything but one of those turns the computer off, although it takes like 10 seconds... so I'm guessing that it boots properly into Windows (XP).
