Dell W3201C 32"
ta7mike
Looking to upgrade from 2005FPW, and was looking at a Dell W3201C 32". Anyone who owns this, can you say good & bad to use this as Bedroom TV and obviously a PC monitor. I am a casual strategy gamer, browse the net, and do occasionally do word on it. I recently purchased a TV card with BeyondTV so want to do more DVR and viewing with it. Thanks
What about the westinghouse 37? Its only a couple of hundred more and has higher 1920x1080 resolution instead of dell's 1366x768.
I'm using one here and, while not an apple cinema display by any means, it is a decent monitor and a good tv. You'll need an external tuner to watch TV (ie cable box, sat box, whatever)
I'm assuming your PC has a late-model DVI port to run the monitor with. You wouldn't want to run the westy on an analog vga signal. Also, the current lvm37-w1 westy doesn't have HDMI like the dell, I think the new lvm37-w3 model is supposed to fix that.
Just a thought...
