Dell vs Viesonic vs Scepte
Spetsnaz201
Still havent made up my decision on which monitor to pick. These 3 monitors seem to fit my budget. Dell seems to have the HDCP support. I cant find any info on the other two, can anyone comfirm that they dont have HDCP.
ViewSonic VG2030WM
http://www.newegg.com/Product/Product.asp?Item=N82E16824116062
SCEPTRE X20WG-Naga
http://www.newegg.com/Product/Product.asp?Item=N82E16824112006
Dell E207WFP
Im leaning towards the Dell because of HDCP support. But it recieved a bad rating from CNET. As I recall they said its bad for games and multimedia.
The other two Im not sure about. It doesnt mention anywhere these two have HDCP support. Both monitors have gottten decent ratings. So I am torn apart. And then theres the 22'' Dell for only 40$ more.
I need some input on which way to lean. Thanks
The 207WFP uses a cheap TN panel and tries to mimic the 2007WFP which has a better panel and lots of inputs on the back.
The Sceptre has known light bleed that's really bad imo. I haven't seen the Viewsonic model in any reviews though.
Gaming is about the only thing TN panels are decent at (aside from office work). They have fast response times, but poor viewing angles and colors.
here's a funny thought, i wonder how the 2007WFP with the crappier lotto panel (PVA) compares to the TN panel of the E207?
One thing to remember about Viewsonic, they usually make pretty good monitors, but they have crappy tech support if you ever have to deal with them.
