Happy00000
- Oct 12, 2009
Unless you are a big gamer and motion bothers you a lot, IPS is generally preferred. It's certainly not a gimmick.
The problem with the Dell 2412 is that it has a heavy antiglare coating that bothers a lot of people. If using in a very bright environment, it may be the lesser of two evils to you, but you should be aware of it. Basically it makes the screen sparkly/grainy on light colored backgrounds.
