dell speedstep slows down system
goodngood
I was playing around with a few laptops and it seems that allowing speedstep in the bios always makes the computer run slower... was wondering if anybody might know why
That's the whole point of Speedstep. Slow down the CPU when it's not being used to save power and reduce heat output. It increments the speed up as CPU demand increases until the max speed is reached.
That is normal.. and It isn't a DELL thing, it is an Intel AND AMD thing.
And yes, some stuff will perform better if you disable speedstep or set the CPU to always run at 100% in the power settings in Windows.
