- Nov 27, 2006
Dell has issued a system update for notebooks that are affected by Nvidias recently announced video problems affecting mobile GPUs. The updates are for the models detailed in the table linked above.
So the question is is this every model of Dell laptop that has a G84/G86 in it? That could go a long why towards Charlie D.'s charge at the INQ that all of these chips are bad.
From what I have read on other websites, all these bios updates do is increase the fan speed. In some cases, it just causes the fan to run at full speed all the time.
So, it is a really half-assed fix. It will just make your laptop noisier, use up its battery quicker, and it does nothing to solve the real problem. The best Dell can hope for is that it allows the GPU to work long enough so that it is out of warranty by the time it dies.
Note: I have not tried any of these updates, this is just what I understand from what I have read elsewhere.
Every model with a G84 or G86 is at risk. That's because only Dell and Nvidia know which specific models and their date of products could actually be screwed. It's likely easier for Dell just to release it for all of these models and not risk it themselves than take a guess based on data of production.
Now, if they really wanted to do the "right" thing it would be to replace these systems but for instance with the M1330 and M1530 those systems are still shipping with Nvidia GPUs (ones hopefully dated late enough to not be messed up). But that is a very expensive under taking and one I don't think a publicly traded company could justify to its stock holders.
Well, I just updated my XPSm1330 which I just got back from repair center. Was probably the most painless BIOS flash ever.
I'm worried that they did not replace the 8400M GS chip at the repair center.
Funny you should mention. I just went to Device manager to see which nvidia adapter is in my T61p.
It is a NVIDIA Quadro FX570M. Now that you mention it. It does get hot. :-(
Most ridiculous "fix" ever. How is running your fans at 100% all the time a fix? They should just replace the defective units.
It figures Dell would go for a quick fix that does nothing to address the real problem.This is why I'll never buy another mass market computer.They screwed me over with their Inspiron 1100 laptops,turned out they had motherboards that self destructed just about the time the warranty expired.Which is probably just what they're hoping for with this update,it will keep the affected systems going just long enough to be out of warranty when they fry.
An add in builder has to have an element of faith in their component suppliers. It should be expected that Dell do this to see how it can lower failure rates before instituting a full "recall and replace". If you owned a company would you not try to postpone a problem beyond your responsibility cheaply before pursuing the most expensive fix?
That's exactly the kind of reasoning that makes Dell a company to be avoided.Their responsibility is to sell products that aren't defective.If a problem occurs,you fix it.They did neither,all they did was take a ticking bomb and lengthened the fuse a little.It's not the consumer's fault that Dell decided to trust Nvidia,so why should they pay for that mistake?
Let Dell go after Nvidia to pay for it.
Note: Prior to the Bios flash I've seen my GPU reach 90C under load. Haven't tested load with the new bios yet though.
inspiron 1420 - Nvidia GeForce 8400M GS
D630 - Quadro NVS 135M
D630C - Quadro NVS 135m
precision m2300 - Quadro FX 360M
Vostro 1310 - Nvidia 8400M GS
Vostro 1400 - 8400M GS
Vostro 1510 - 8400M GS
Vostro 1710 - 8600M GT
xps m1330 - 8400M GS
xps m1530 - 8600M GT
Looks like there may be a reason to give the Inq some credit here. They're all 84's and 86's for the mobile single GPU models.
Well I'm glad they did this AFTER they replaced my laptop's mobo
argh, can't edit, but what exactly does this fix do?
Dell says the fix tweaks fan control profiles to "help regulate GPU temperature fluctuations". In other words, the fan controllers should make them spin faster, to keep the chips cooler, which is what's causing them to fail rapidly.
I flashed my BIOS and everything went smoothly. I noticed slight artifacting and random lines upon the startup of Windows, though. Hasn't since happened.
I was on the laptop for a full hour prior. And no, the fans do not run at full speeds. Not even half. Because here I sit, posting from my M1530, and the only fan activity going on is minimal.Your chip may not have "cooked" yet. but your battery life will suck from now on if they just running fans at full revs.
So basically, fan running more often?
