Hey guys! I just picked up an old Dell Precision 610 workstation that wasn't being used. It has dual Pentium II Xeon processors, 512 megs of ECC ram, and four hardrives. Three of the hardrives are 9.1 gigabyte Seagate Cheetah 10k rpm drives and one of them is a 9.1 gigabyte Quantum 10k rpm drive. I updated the motherboard to the latest bios. It took me a while to figure out how this old system works. It has an SCSI Ultra 2 160 setup with an Adaptec Raid 5 addon card. The latest drivers they made for this SCSI setup was for Windows 2000, and it luckily worked with Windows 2003 Server. I setup the four SCSI drives in RAID 5 and installed Windows 2003. Sisoft Sandra reports that I am getting about 20 megabytes per second out of the Raid 5 setup. Does this sound correct for the specifications I have listed?
The main point of this thread was to ask if it would make a noticable difference in performance if I upgraded the ram on the Raid 5 card. Currently it has a 16 Meg EDO dimm installed. It can be upgraded to 64 megs. I just wanted to know if it would make any noticable difference for my four drive raid setup.
Finally the last thing I wanted to ask is this. The workstation has all four drives hooked up to the same ribbon cable. Would this be a source of bottle neck?
Thanks guys!
Thanks guys!
