Dell R210II and SSD
george88
Hello, Long time reader, first time poster =]
Having issues with SSD and R210II, Freezing/Slow Speeds
Specs:
Dell R210II
xeon e3 1240
4x2GB ECC RAM
Corsair Force Series 3 120gb SSD.
Windows Server 2008 Standard r2
Onboard Intel C202 SATA Controller
Installed newest AHCI drivers
I have connected the SSD to the onboard port and in BIOS i set it to AHCI mode, installed windows, then ran MS Updates, as it was installing it went BSOD, when it booted into windows I was unable to run updates again, I recieved 2 error codes, 1 for corrupted files.
So I reinstalled Windows again, ran updates, same thing. So I updated the firmware to the latest version on the SSD, reinstalled windows, ran updates, and success, installed fine, however it was extremely slow, slower then the HDD i had in there before. So i downloaded ATTO to test the SSD, It ran the first run of 0.5 then completely froze, so I downloaded Intel Rapid Storage App to see if it reports anything, when i go to run it, it says This program has stopped working, so I cannot access it. I tried a few more times to run ATTO, and managed to get 1 run out of it.
as you can see 0.5, 1.0, 2.0 are slow.
So I take it out and plug the SSD into my Desktop Computer, and run ATTO on there, and this is what I get:
So I know the SSD works perfectly fine.
I plug it back into the r210II, and then set the mode from AHCI to ATA and this is what I get:
It performs better on 0.5, 1.0, 2.0, but on everything else its slower.
I have secure erased it and reinstalled, still the same?
I thought it might be the controller onboard, so I tested the 250GB HDD on there an it came out perfectly normal with AHCI enabled.
Thoughts :/?
Reply
Very nice, I'm thinking of getting a couple of these in the new year (you can't beat the the price/ performance ratio).
What version did you go for, two or four drives? Also, how loud is it? and Welcome!
Have you tried a Firmware update on the SSD?
I've got 12 in an array, and 1 was causing it to behave very poorly- system hangs. I updated all of the firmware and it's rock solid now.
2x250gb HDD mate, and it can get loud, very loud!
Yes updated firmware to the latest version, what chipset are you using? Is it on a Intel C202 series?
No this is on my home machine. I've got an LSI 9265-8i with a Chenbro 23601 and 12 x OCZ Vertex 3 Max IOPS drives.
anyone know if this is a MOBO problem or SSD problem? Or even compatibilty problem?
